Zum Hauptinhalt wechseln
Sony Vaio Fit SVF15N26CXB Hard Drive Replacement
Was du brauchst
  1. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 2, Bild 1 von 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 3, Bild 1 von 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 3, Bild 2 von 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 2
    • Remove the four 3.20mm Phillips #00 screws from the hard drive.
  6. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 6, Bild 1 von 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 6, Bild 2 von 3 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Use a spudger to flip up the black latch on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors and fold them over the hard drive.
    • Disconnect the hard drive and remove.
  7. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 7, Bild 1 von 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Remove the four 3.70mm Phillips #00 screws from the hard drive mounting case.
    • Carefully peel foil tray off of hard drive.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S2-G4, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,160
