Einleitung
This guide to help you replace the damaged battery to restore your LG X Power back to its former glory.
Was du brauchst
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
lg x power mobail sarkit board+ bettery kaha pe milegi
Were can i buy the battery?
thx for rundown
On my H700 Venture....only have to remove 3 screws on the charger port end of the phone to directly access the battery connection. No messing with cameras or motherboard moving. Be aware once you open phone it will no longer be waterproof. Battery from Amazon.
May not be worth the effort. Replace battery (twice) and all I get is a gray battery icon on the screen with a red flashing question mark when I hook up original equipment LG charger....for hours.
Bought a renewed H700 on Amazon, works great. My bad...I had not backed up my contact list from the phone internal storage...learned the hard way "internal" storage is not the SIM card. Anyone know how to recover contact list from a dead phone ? Contact me at heyinway@yahoo.com Thanks !
Hey, great guide, thank you for going through the effort to document what it looks like.
It would have helped me to know where to insert the tool when removing the mid-frame -- I didn't know where to insert the tool or what the mid-frame will look like once it's on its way off the rest of the phone.
Best regards,
Yena
