Einleitung
The buttons on the user interface panel can become broken or stuck. This guide will show how to replace the user interface panel on the Canon PowerShot SD1400 IS.
Was du brauchst
Remove the four 2.0 mm Phillips screws of the camera using the J00 bit from the 54-bit Driver Kit. There are two screws on both sides.
Remove the front face panel of the camera by hand using firm pressure.
If one point of the face is stuck to the body, check if there is a screw preventing the front face from coming off.
Remove the user interface panel by hand. The panel may fall out on its own, this is normal.
Replace the user interface panel by setting it in position.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
