Zum Hauptinhalt wechseln
Heating Element Contacts
Was du brauchst
  1. Heating Element Contacts, Heating Element Contacts: Schritt 1, Bild 1 von 3 Heating Element Contacts, Heating Element Contacts: Schritt 1, Bild 2 von 3 Heating Element Contacts, Heating Element Contacts: Schritt 1, Bild 3 von 3
    • Flip the coffee maker over so the bottom is facing upwards.
    • Use the screwdriver with size 4 extension with the T10 Torx bit to remove all four 17 mm long screws.
    • Lift the bottom cover off the bottom of the coffee maker.
  2. Heating Element Contacts: Schritt 2, Bild 1 von 2 Heating Element Contacts: Schritt 2, Bild 2 von 2
    • If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
    • Solder iron can cause burns if used improperly
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UW Stout, Team S8-G1, Ogden Spring 2018 Mitglied von UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Cuisinart Drip Coffee Maker:
Model CBC-6500PCC
In use:
Less than one year.
Problem:
Not heating
Cause:
Blown thermal fuse (240C) connected in series with one side of heating element (there are two, each one connected in series and attached directly to each side of the heating element.) Not replaceable by itself.
Remedy:
Replacement under warranty or purchase a used one at Goodwill, Salvation Army, Value Village, local online personal seller, etc.
brian.steven.richmond - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 2,942
