Zum Hauptinhalt wechseln
Lenovo ThinkPad Yoga 260 Repair Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Ensure the device is off and unplugged.
    • Remove the stylus from its port and set aside.
  2. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, gently unscrew the eight 1.3 mm Phillips #1 screws until you hear an audible click.
    • The screws will not separate from the bottom cover when loose.
  3. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 3, Bild 2 von 2
    • The bottom cover is attached via several plastic clips located around the edges of the bottom cover.
    • Using a plastic opening tool, gently pry the bottom cover from the laptop.
    • Work the plastic opening tool around the edges of the bottom cover undoing all of the plastic clips, as shown in the picture.
  4. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 4, Bild 2 von 2
    • Place your fingers around the edges of the cover and remove it.
  5. Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: Schritt 5, Bild 1 von 3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: Schritt 5, Bild 2 von 3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement, Battery: Schritt 5, Bild 3 von 3
    • Fold back the plastic cover to access the battery connection.
    • Remove the battery connection using your two index fingers.
    • Gently separate the connectors.
  6. Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad Yoga 260 Repair Battery Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the two 1.3 mm Phillips #1 fasteners using a Phillips #1 screwdriver and set them aside.
    • Lift the battery free from its mounting and remove it.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S2-G3, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G3, Eyestone Spring 2018
USFT-EYESTONE-S18S2G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 126
Insgesamt: 7,195
