Zum Hauptinhalt wechseln
LG Phoenix 2 Camera Replacement
Was du brauchst
  1. LG Phoenix 2 Camera Replacement, Battery: Schritt 1, Bild 1 von 3 LG Phoenix 2 Camera Replacement, Battery: Schritt 1, Bild 2 von 3 LG Phoenix 2 Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Camera Replacement: Schritt 2, Bild 1 von 3 LG Phoenix 2 Camera Replacement: Schritt 2, Bild 2 von 3 LG Phoenix 2 Camera Replacement: Schritt 2, Bild 3 von 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Camera Replacement, Rear Camera: Schritt 3, Bild 1 von 2 LG Phoenix 2 Camera Replacement, Rear Camera: Schritt 3, Bild 2 von 2
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
  4. LG Phoenix 2 Camera Replacement: Schritt 4, Bild 1 von 3 LG Phoenix 2 Camera Replacement: Schritt 4, Bild 2 von 3 LG Phoenix 2 Camera Replacement: Schritt 4, Bild 3 von 3
    • Remove all 9 screws on the back by using a Phillips head #00 screwdriver.
    • To remove the screws rotate them counterclockwise.
  5. LG Phoenix 2 Camera Replacement: Schritt 5, Bild 1 von 3 LG Phoenix 2 Camera Replacement: Schritt 5, Bild 2 von 3 LG Phoenix 2 Camera Replacement: Schritt 5, Bild 3 von 3
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
  6. LG Phoenix 2 Camera Replacement: Schritt 6, Bild 1 von 3 LG Phoenix 2 Camera Replacement: Schritt 6, Bild 2 von 3 LG Phoenix 2 Camera Replacement: Schritt 6, Bild 3 von 3
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
  7. LG Phoenix 2 Camera Replacement: Schritt 7, Bild 1 von 3 LG Phoenix 2 Camera Replacement: Schritt 7, Bild 2 von 3 LG Phoenix 2 Camera Replacement: Schritt 7, Bild 3 von 3
    • Insert the flat end of the Spudger or the plastic opening tool underneath the camera connector.
    • Gently lever the camera connector free.
    • Once disconnected, take the camera out.
  8. LG Phoenix 2 Camera Replacement: Schritt 8, Bild 1 von 3 LG Phoenix 2 Camera Replacement: Schritt 8, Bild 2 von 3 LG Phoenix 2 Camera Replacement: Schritt 8, Bild 3 von 3
    • The front camera can be removed in a similar way as the rear camera. See previous step.
Abschluss
USF Tampa, Team S2-G2, Eyestone Spring 2018 Mitglied von USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 676
