Zum Hauptinhalt wechseln
HP Pavilion Sleekbook 15-b000 Motherboard Replacement
Was du brauchst
  1. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Case: Schritt 9, Bild 1 von 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 12, Bild 1 von 3 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 12, Bild 2 von 3 HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Hard Drive: Schritt 13, Bild 1 von 1
    • Remove the 4 x 5.5 mm screws connecting the hard drive tot he case.
  14. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Remove hard drive from bracket being careful of it's cable.
  15. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Disconnect cable from hard drive.
  16. HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Motherboard: Schritt 16, Bild 1 von 2 HP Pavilion Sleekbook 15-b000 Motherboard Replacement, Motherboard: Schritt 16, Bild 2 von 2
    • Disconnect motherboard cable from left side USB and jacks
  17. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the one 3.5mm Phillips #1 screw from the WiFi chip
  18. HP Pavilion Sleekbook 15-b000 Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Remove motherboard.
Abschluss
Sam Barkley
983 Reputation
8 Anleitungen geschrieben
USF Tampa, Team S11-G2, Cheng Spring 2018 Mitglied von USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 597
