Zum Hauptinhalt wechseln
Altec Lansing Mini Lifejacket 2 Battery Replacement
Was du brauchst
  1. Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: Schritt 1, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: Schritt 1, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 2, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 2, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 2, Bild 3 von 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 3, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 4, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 4, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 5, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 5, Bild 2 von 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 6, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 6, Bild 2 von 2
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 8, Bild 1 von 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 9, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 9, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement: Schritt 9, Bild 3 von 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: Schritt 10, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: Schritt 10, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Battery Replacement, Battery: Schritt 10, Bild 3 von 3
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Stephen Albrecht
1.008 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S3-G2, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Mitglieder
10 Kommentare
Where can you get the batteries? Altec Lansing doesn’t carry them.
alanp5 - Antwort
Search for MCR18650 battery. They are available.
F Hickisch - Antwort
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
rudy.ch.garcia - Antwort
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
Edgar Corral (Tramarius) - Antwort
For the mini life jacket 3 can you send what link you had for the battery?
Malena Reyes -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 41
Letzte 30 Tage: 195
Insgesamt: 21,245
