Einleitung
If the battery in your Altec Lansing Mini Lifejacket 2 isn't holding a charge or is showing signs of failure, use this guide to replace it.
Was du brauchst
Use the spudger to remove the eight black pins from the front and back of the wire screens.
Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
Slide the mounting plate out to remove it.
Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
Search for MCR18650 battery. They are available.
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
For the mini life jacket 3 can you send what link you had for the battery?
