Zum Hauptinhalt wechseln
Zoomer Meowzies Battery Replacement
Was du brauchst
  1. Zoomer Meowzies Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Zoomer Meowzies Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: Schritt 2, Bild 1 von 2 Zoomer Meowzies Battery Replacement: Schritt 2, Bild 2 von 2
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
Abschluss
USF Tampa, Team S6-G2, Eyestone Spring 2018 Mitglied von USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 851
