Zum Hauptinhalt wechseln
Samsung Galaxy J1 Front-Facing Camera Replacement
Was du brauchst
  1. Samsung Galaxy J1 Front-Facing Camera Replacement, Midframe: Schritt 1, Bild 1 von 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 2, Bild 2 von 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Front-Facing Camera Replacement, Front-Facing Camera: Schritt 5, Bild 1 von 2 Samsung Galaxy J1 Front-Facing Camera Replacement, Front-Facing Camera: Schritt 5, Bild 2 von 2
    • Use the flat end a spudger to disconnect the front-facing camera cable connecter.
  6. Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy J1 Front-Facing Camera Replacement: Schritt 6, Bild 2 von 2
    • Using tweezers, or your fingers, remove the front-facing camera.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Sean Kramer
1.452 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S5-G4, Eyestone Spring 2018 Mitglied von USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 35
Insgesamt: 2,963
