Zum Hauptinhalt wechseln
HP 15-f009wm Hard Drive Replacement
Was du brauchst
  1. HP 15-f009wm Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP 15-f009wm Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn laptop upside down.
    • Flip the lock switch to the unlocked setting.
  2. HP 15-f009wm Hard Drive Replacement: Schritt 2, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 2, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Flip the release switch.
    • Once the flip is switched, the battery should pop out.
  3. HP 15-f009wm Hard Drive Replacement: Schritt 3, Bild 1 von 2 HP 15-f009wm Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Slide the battery out.
  4. HP 15-f009wm Hard Drive Replacement, RAM: Schritt 4, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement, RAM: Schritt 4, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement, RAM: Schritt 4, Bild 3 von 3
    • Remove the two Phillips #1 screws from the RAM panel.
  5. HP 15-f009wm Hard Drive Replacement: Schritt 5, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 5, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to pop the panel off.
  6. HP 15-f009wm Hard Drive Replacement: Schritt 6, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 6, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
  7. HP 15-f009wm Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the RAM chip from the laptop.
  8. HP 15-f009wm Hard Drive Replacement, Hard Drive: Schritt 8, Bild 1 von 1
    • Remove the sixteen 7mm Phillips #1 screws from the bottom panel.
  9. HP 15-f009wm Hard Drive Replacement: Schritt 9, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 9, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 9, Bild 3 von 3
    • Pull the disk drive out of the laptop.
  10. HP 15-f009wm Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Remove the three 2mm Phillips #00 screws found underneath the disk drive.
  11. HP 15-f009wm Hard Drive Replacement: Schritt 11, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 11, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 11, Bild 3 von 3
    • Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
    • Pull the Wi-Fi card out of the motherboard.
  12. HP 15-f009wm Hard Drive Replacement: Schritt 12, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 12, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 12, Bild 3 von 3
    • Open the laptop.
    • Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
  13. HP 15-f009wm Hard Drive Replacement: Schritt 13, Bild 1 von 2 HP 15-f009wm Hard Drive Replacement: Schritt 13, Bild 2 von 2
    • Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
    • Lift the keyboard from the laptop.
    • Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
  14. HP 15-f009wm Hard Drive Replacement: Schritt 14, Bild 1 von 1
    • Remove the five 7mm Phillips #1 screws found underneath the keyboard.
  15. HP 15-f009wm Hard Drive Replacement: Schritt 15, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 15, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 15, Bild 3 von 3
    • Use a spudger to lift the black tabs on the ZIF connectors.
    • Remove the ribbon cables from the ZIF connectors.
  16. HP 15-f009wm Hard Drive Replacement: Schritt 16, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 16, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 16, Bild 3 von 3
    • Use a plastic opening tool to pop the palm rest off of the laptop.
    • Lift and remove the palm rest.
  17. HP 15-f009wm Hard Drive Replacement: Schritt 17, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 17, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 17, Bild 3 von 3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
  18. HP 15-f009wm Hard Drive Replacement: Schritt 18, Bild 1 von 2 HP 15-f009wm Hard Drive Replacement: Schritt 18, Bild 2 von 2
    • Remove the single 7mm Phillips #1 screw from the USB/AUX board.
    • Remove the USB/AUX board from the laptop.
  19. HP 15-f009wm Hard Drive Replacement: Schritt 19, Bild 1 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 19, Bild 2 von 3 HP 15-f009wm Hard Drive Replacement: Schritt 19, Bild 3 von 3
    • Lift the Hard Drive from the laptop.
    • Disconnect the hard drive from the motherboard.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Birchler
1.008 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S2-G2, Nance Spring 2018 Mitglied von USF Tampa, Team S2-G2, Nance Spring 2018
USFT-NANCE-S18S2G2
4 Mitglieder
3 Kommentare
This guide helped me so much with my laptop, thanks m8
Connor Cornelison - Antwort
Thank you for this excellent write-up!
Dan Snow - Antwort
Hello, i have a question. How much of capacity and technology i could use to upgrade my hard drive?
Samuel Arreaza - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 3,853
