Einleitung
In this guide, we will be showing you how to remove and replace the Memory Module.
Was du brauchst
Remove the screw that secures the access panel to the computer.
Use your fingertips to spread apart the securing clips on each end of the memory module connector until the memory module pops up and remove the memory module from its connector on the system board by drawing the module from the system board at 45-degree angle.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
