Zum Hauptinhalt wechseln
Memorex CD Alarm Clock Radio CD Lid Spring Replacement
Was du brauchst
  1. Memorex CD Alarm Clock Radio CD Lid Spring Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 1 von 3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 2 von 3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 3 von 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio CD Lid Spring Replacement: Schritt 2, Bild 1 von 3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement: Schritt 2, Bild 2 von 3 Memorex CD Alarm Clock Radio CD Lid Spring Replacement: Schritt 2, Bild 3 von 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio CD Lid Spring Replacement, CD Lid Spring: Schritt 3, Bild 1 von 2 Memorex CD Alarm Clock Radio CD Lid Spring Replacement, CD Lid Spring: Schritt 3, Bild 2 von 2
    • Locate the spring and the spring's retaining piece.
    • There will be a screw that holds the retaining piece in place.
    • Use a screwdriver to remove the screw and the retaining piece.
  4. Memorex CD Alarm Clock Radio CD Lid Spring Replacement: Schritt 4, Bild 1 von 2 Memorex CD Alarm Clock Radio CD Lid Spring Replacement: Schritt 4, Bild 2 von 2
    • Grasp and remove the spring using tweezers.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 318
