Einleitung
This guide is for removing the ThinkPad X100e's LCD display and replacing it with a new one.
Was du brauchst
Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
Fold the panel over until a strip of black tape is visible.
Peel the tape down until you get to the base.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
What can be used as a replacement screen, as it's listed not for sale?
