Was du brauchst
Insert the opening pick/tool into the slit between the case and the body of the phone. It can be easier to insert near buttons. Make your way around the case as you use the pick/tool to lift the cover from the body.
Once completely loose lift the cover off and set aside.
This is a good opportunity to blow out any dust that has accumulated.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using your Phillips 000 remove the eight screws found in the waterproof cover.
Once the screws are removed, take your pick tool and make your way around the case as you use the pick/tool to lift the waterproof cover from the body.
Once loosen by the pick carefully remove the cover from the base and set aside.
Starting near the lower area of the phone, carefully press the battery towards the top of the phone and then lift up.
Lift the battery up and over the top of the phone to expose the battery cable and port.
Using tweezers and opening tool, flip the lock on the port and carefully pull out the cable.
19 weitere Nutzer:innen haben diese Anleitung absolviert.
7 Kommentare
As of June 2018 there is no new SCP-67LBPS , battery replacement available for the pro.. only used batteries from cannibalized phones.
for anyone interested here is a video of df pro battery removal
I am going to try method.
No new battery to buy for this phone? Maybe can buy from Kyocera?
FidgetFidget OEM New Battery for Kyocera Duraforce PRO E6820 E6810 SCP-67LBPS 3240mAh 3.8V https://www.amazon.com/dp/B07H2BNLCZ/ref...
Shopping sites in Japan are still selling SCP-67LBPS . Maybe they can’t send batteries to US. If you have a friend in Japan. You can ask him/her to get it.
