Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Hoover LiNX zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Hoover LiNX Handle Teardown, Hoover LiNX Handle Teardown: Schritt 1, Bild 1 von 1
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX Handle Teardown: Schritt 2, Bild 1 von 1
    • Remove the handle by pulling it up.
  3. Hoover LiNX Handle Teardown: Schritt 3, Bild 1 von 1
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX Handle Teardown: Schritt 4, Bild 1 von 2 Hoover LiNX Handle Teardown: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX Handle Teardown: Schritt 5, Bild 1 von 2 Hoover LiNX Handle Teardown: Schritt 5, Bild 2 von 2
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX Handle Teardown: Schritt 6, Bild 1 von 2 Hoover LiNX Handle Teardown: Schritt 6, Bild 2 von 2
    • Remove the silver plastic cover using the plastic opening tool.
Mark Nelson
452 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S7-G4, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
I have Hoover Linx cordless stick vacuum. Older but was very lightly used. Everything is clean moves freely, powers up, has suction, like new brush roller and belt. It all turns freely. But...turn the vacuum on...and the gear the brush belt goes around does not turn. Was hoping to find a more detailed disassembly. Anyone out there have to address that problem? Too bad as its a good little vacuum for small pickup stuff. I've alway used at large standard size for regular vacuuming thus it being lightly used.
Lori - Antwort
OK, I found the instructions on the site here and disassembled it. The wires seem intact, nothing appeared pinched. Put it back together; I don't see that the company sells the replacement motor. I saw a few online but hate to spend 65 + Ship for a secondhand motor that may not even work.
Lori - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 2,506
