Zum Hauptinhalt wechseln
Disassembling Samsung Galaxy Ace Logic Board
Was du brauchst
  1. Disassembling Samsung Galaxy Ace Logic Board, Logic Board: Schritt 1, Bild 1 von 2 Disassembling Samsung Galaxy Ace Logic Board, Logic Board: Schritt 1, Bild 2 von 2
    • Remove the battery cover and the battery
  2. Disassembling Samsung Galaxy Ace Logic Board: Schritt 2, Bild 1 von 2 Disassembling Samsung Galaxy Ace Logic Board: Schritt 2, Bild 2 von 2
    • Remove the 7 silver screws with a Phillips #000 screw driver.
    • Sometimes the green one could be a little difficult. Use a tweezer for get it out.
  3. Disassembling Samsung Galaxy Ace Logic Board: Schritt 3, Bild 1 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 3, Bild 2 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 3, Bild 3 von 3
    • Lift gently the back cover from the screen assembly from the bottom.
  4. Disassembling Samsung Galaxy Ace Logic Board: Schritt 4, Bild 1 von 2 Disassembling Samsung Galaxy Ace Logic Board: Schritt 4, Bild 2 von 2
    • Use a flat tweezer for take off the flexible on/off button from the frame.
    • Be careful, the flexible is very delicate; it could be cut if you go too fast.
  5. Disassembling Samsung Galaxy Ace Logic Board: Schritt 5, Bild 1 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 5, Bild 2 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 5, Bild 3 von 3
    • Use a flat tweezer and take off gently Flexible volume button from the left side.
    • Do the same for the right side.
    • Then lift the flex slowly, if you go fast you may cut the cable.
  6. Disassembling Samsung Galaxy Ace Logic Board: Schritt 6, Bild 1 von 1
    • Lift the microphone from the logic board.
  7. Disassembling Samsung Galaxy Ace Logic Board: Schritt 7, Bild 1 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 7, Bild 2 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 7, Bild 3 von 3
    • Lift the sensor/earpiece cable with the opening tool.
    • Don't force, you may damage the soldering.
  8. Disassembling Samsung Galaxy Ace Logic Board: Schritt 8, Bild 1 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 8, Bild 2 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 8, Bild 3 von 3
    • Lift the logic board from the right side.
    • Use the removal tool to unplug the display cable from the logic board.
    • You can now separate the Logic board from the display assembly.
  9. Disassembling Samsung Galaxy Ace Logic Board: Schritt 9, Bild 1 von 2 Disassembling Samsung Galaxy Ace Logic Board: Schritt 9, Bild 2 von 2
    • Use the removal tool to unclip the camera module from the Logic board.
  10. Disassembling Samsung Galaxy Ace Logic Board: Schritt 10, Bild 1 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 10, Bild 2 von 3 Disassembling Samsung Galaxy Ace Logic Board: Schritt 10, Bild 3 von 3
    • Use the removal tool or a spudger to unplug speaker module cable
    • And separate the speaker module from Logic board.
    • Be caution, the module is fixed by plastic teeth to the Logic board. Don't force, just make little wave-movements and the speaker comes on his own.
  11. Disassembling Samsung Galaxy Ace Logic Board: Schritt 11, Bild 1 von 1
    • Now you can work with the Logic board.
Abschluss
34 weitere Nutzer:innen haben diese Anleitung absolviert.
finster
1.986 Reputation
1 Anleitung geschrieben
2 Kommentare
Thanks for the post. This is really Helpful
Dave Dayanan - Antwort
im curently selling one thx to you
Kyle at work - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 27
Insgesamt: 26,713
