Zum Hauptinhalt wechseln
Dell Alienware M17x R2 Display Assembly Replacement
Was du brauchst
  1. Dell Alienware M17x R2 Display Assembly Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid damage to the display, you must not disassemble your Edge-to-Edge display assembly.
    • Remove the four screws (two from each hinge) that secure the display assembly to the computer base.
  2. Dell Alienware M17x R2 Display Assembly Replacement, Lifting the Display Assembly: Schritt 2, Bild 1 von 1
    • Bend the display assembly towards the computer base at a 45-degree angle and lift the display assembly off the computer.
  3. Dell Alienware M17x R2 Display Assembly Replacement, Align the Screw Holes: Schritt 3, Bild 1 von 1
    • Align the screw holes on the display hinges with the computer base.
  4. Dell Alienware M17x R2 Display Assembly Replacement, Replace the Screws: Schritt 4, Bild 1 von 1
    • Replace the four screws (two on each hinge) that secure the display assembly to the computer base.
Abschluss
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 1,365
