Zum Hauptinhalt wechseln
Altec Lansing Mini Lifejacket 2 Speaker Replacement
Was du brauchst
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 2, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 2, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 2, Bild 3 von 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 3, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove both black and orange layers from the speaker body.
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 4, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 4, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 4, Bild 3 von 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 5, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 6, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Pull the case apart to access the interior components.
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 9, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 9, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 9, Bild 3 von 3
    • To remove the back panel, gently pull out its wire harness.
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: Schritt 10, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: Schritt 10, Bild 2 von 2
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 11, Bild 1 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 11, Bild 2 von 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 11, Bild 3 von 3
    • To remove the speaker, gently pull out the its wire harness.
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 12, Bild 1 von 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: Schritt 12, Bild 2 von 2
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Stephen Albrecht
1.029 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S3-G2, Nance Spring 2018 Mitglied von USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Mitglieder
2 Kommentare
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Antwort
Where can I get this speaker parts?
T Rex movies - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 34
Insgesamt: 4,032
