Zum Hauptinhalt wechseln
Dell Axim X30 Screen Replacement
Was du brauchst
  1. Dell Axim X30 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Dell Axim X30 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Dell Axim X30 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Remove the four rubber feet with your fingers.
  2. Dell Axim X30 Screen Replacement: Schritt 2, Bild 1 von 2 Dell Axim X30 Screen Replacement: Schritt 2, Bild 2 von 2
    • Trigger battery release by inserting a nylon spudger into the battery release tab.
    • Slide tab and pull upwards on the battery to remove. Use the finger slots near the battery.
  3. Dell Axim X30 Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the four 12.7mm screws under rubber feet with a JIS #0 screwdriver.
  4. Dell Axim X30 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • The back panel should just pop off.
  5. Dell Axim X30 Screen Replacement: Schritt 5, Bild 1 von 3 Dell Axim X30 Screen Replacement: Schritt 5, Bild 2 von 3 Dell Axim X30 Screen Replacement: Schritt 5, Bild 3 von 3
    • Disconnect ribbon cables.
    • You may need to use a little force to disconnect them.
    • Disconnect red and white wired connector for speaker and motherboard battery.
  6. Dell Axim X30 Screen Replacement: Schritt 6, Bild 1 von 2 Dell Axim X30 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove three 12.7mm JIS #0 screws.
  7. Dell Axim X30 Screen Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove motherboard.
  8. Dell Axim X30 Screen Replacement: Schritt 8, Bild 1 von 2 Dell Axim X30 Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
  9. Dell Axim X30 Screen Replacement: Schritt 9, Bild 1 von 2 Dell Axim X30 Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove black plastic board.
  10. Dell Axim X30 Screen Replacement: Schritt 10, Bild 1 von 2 Dell Axim X30 Screen Replacement: Schritt 10, Bild 2 von 2
    • Gently apply pressure on the right plastic frame by plastic clip marked on the picture.
    • Apply pressure to the bottom of the screen and press it towards you.
    • Remove screen from plastic case.
Abschluss
IUPUI, Team S2-G5, Harley Spring 2018 Mitglied von IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 10
Insgesamt: 761
