Einleitung
Your screen might need replacement if there are any noticeable cracks on screen or if you are experiencing persistent flickering during use of your Lenovo IdeaPad Flex4-1130.
Was du brauchst
Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
Use the spudger to remove the plastic caps, uncovering the screws underneath.
Remove the two 6mm screws.
Use the black nylon spudger to remove the long plastic covering underneath the screen.
Remove three 6mm screws.
Use the black nylon spudger to lift and separate the screen from the plastic back cover.
