Zum Hauptinhalt wechseln
Dell Vostro 1700 Memory Module Replacement
Was du brauchst
  1. Dell Vostro 1700 Memory Module Replacement, Removing the Battery: Schritt 1, Bild 1 von 1
    • Slide and click the battery release latches to keep them open.
    • Slide the battery out of the bay.
  2. Dell Vostro 1700 Memory Module Replacement, Removing the Hinge Cover: Schritt 2, Bild 1 von 1
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Ease the hinge cover up, moving from right to left, and remove it.
  3. Dell Vostro 1700 Memory Module Replacement, Removing the Keyboard: Schritt 3, Bild 1 von 1
    • Remove the four screws at the top of the keyboard.
    • NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and timeconsuming to replace. Be careful when removing and handling the keyboard.
    • Slide the keyboard toward the back of the computer to disengage the notch on the keyboard from the tab on the base of the computer.
    • Lift and remove the keyboard.
  4. Dell Vostro 1700 Memory Module Replacement, Removing the Memory Module: Schritt 4, Bild 1 von 1
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the memory module from the connector.
Ziellinie
Johnathan Hammond
44.953 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 173
