Zum Hauptinhalt wechseln
LG 305C Camera Replacement
Was du brauchst
  1. LG 305C Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Pry open the back case on the device with a plastic opening tool and remove it.
  2. LG 305C Camera Replacement: Schritt 2, Bild 1 von 1
    • Pry the battery out of the device with a plastic opening tool and remove it.
  3. LG 305C Camera Replacement, MicroSD card: Schritt 3, Bild 1 von 1
    • Dislodge the microSD card from the microSD card slot using your index finger and remove it.
  4. LG 305C Camera Replacement, Internal Casing: Schritt 4, Bild 1 von 1
    • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
  5. LG 305C Camera Replacement: Schritt 5, Bild 1 von 1
    • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
  6. LG 305C Camera Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
  7. LG 305C Camera Replacement: Schritt 7, Bild 1 von 1
    • Pry open the top part of the internal casing with the plastic opening tool and remove it.
  8. LG 305C Camera Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Pry the screen from the internal circuit board with a plastic opening tool and remove it.
  9. LG 305C Camera Replacement, Camera: Schritt 9, Bild 1 von 1
    • Pry the camera from the internal circuit board with the plastic opening tool and remove it.
  10. LG 305C Camera Replacement: Schritt 10, Bild 1 von 1
    • Detach the camera completely by using the spudger tool to poke through the camera attachment holes.
Abschluss
Ashley Kidwell
427 Reputation
5 Anleitungen geschrieben
IUPUI, Team S6-G1, Baechle Spring 2018 Mitglied von IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 140
