Zum Hauptinhalt wechseln
HP Envy Sleekbook m6-k010dx Keyboard Replacement
Was du brauchst
  1. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the twelve 9 mm Phillips #00 screws.
  2. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 2, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool and your hands to remove the bottom cover.
  3. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the battery power cable from the motherboard.
  4. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the six 6 mm Phillips #00 screws from the battery.
  5. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 5, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Lift the battery out of the laptop.
  6. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Fan: Schritt 6, Bild 1 von 1
    • Remove two 3mm Phillips #00 screws from the fan.
  7. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 7, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the fan cable by pulling it out of the motherboard socket.
  8. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 8, Bild 1 von 1
    • Lift the fan upwards to remove it from the computer.
  9. HP Envy Sleekbook m6-k010dx Keyboard Replacement, Keyboard: Schritt 9, Bild 1 von 1
    • Flip up the black tab on the ZIF connector and pull the blue and white flex cable connecting the touchpad to the motherboard.
  10. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 10, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Remove three 3mm Phillips #00 screws from the SD card board.
    • Remove the SD card board.
  11. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 11, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 11, Bild 2 von 2
    • In order to remove the RAM, pull each silver clip (one at a time) away from the RAM.
    • The RAM chip should pop up. Gently remove the RAM from the motherboard.
  12. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 12, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Remove four 3mm Phillips #00 screws from the heatsink.
    • Lift the heat sink out from the device and set it aside.
  13. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 13, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the black and white antenna wires from the Wi-Fi card.
  14. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 14, Bild 1 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 14, Bild 2 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 14, Bild 3 von 3
    • Remove the two 3mm Phillips #00 screws that secure the speaker to the device.
    • Remove the four 4mm Phillips #00 screws from the bracket.
    • Locate the speaker cable connecting the speaker to the audio board. Gently tug on this cable to dislodge. Set the speaker aside.
  15. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 15, Bild 1 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 15, Bild 2 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 15, Bild 3 von 3
    • Remove the two 3mm Phillips #00 screws that secure the RJ-45 module.
    • Lift the white tab on the ZIF connector and pull the ribbon cable out.
  16. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 16, Bild 1 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 16, Bild 2 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 16, Bild 3 von 3
    • Remove the 3mm Phillips #00 screw connecting the chip to the housing.
    • Lift up silver bracket.
    • Lift up the white flap on the ZIF connector and remove the purple ribbon cable.
  17. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 17, Bild 1 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 17, Bild 2 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 17, Bild 3 von 3
    • Remove the cover for the RM-45 port.
    • Gently lift and remove the chip from its housing.
  18. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 18, Bild 1 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 18, Bild 2 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 18, Bild 3 von 3
    • Remove the 4mm Phillips #00 screws.
    • Remove the silver 3mm Phillips 3 mm screw.
    • Lift all three black flaps in the ZIF connectors and remove the attached ribbon cables.
  19. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 19, Bild 1 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 19, Bild 2 von 3 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 19, Bild 3 von 3
    • Use your hand and gently remove the connector to the back up battery for the motherboard.
    • Remove the four 4mm Phillips #00 screws from the motherboard.
    • Lift the board at an angle and pull outwards to dislodge it from the device.
  20. HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 20, Bild 1 von 2 HP Envy Sleekbook m6-k010dx Keyboard Replacement: Schritt 20, Bild 2 von 2
    • Remove the thirteen silver 3mm Phillips #00 screws that secure the keyboard to the frame.
    • Lift up the keyboard from the bracket and pull outwards to remove the keyboard from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
codi whittaker
508 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S1-G4, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G4, Nance Spring 2018
USFT-NANCE-S18S1G4
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 1,881
