Zum Hauptinhalt wechseln
DBPOWER T20 Speaker Replacement
Was du brauchst
  1. DBPOWER T20 Speaker Replacement, DBPOWER T20 Disassembly: Schritt 1, Bild 1 von 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Speaker Replacement: Schritt 3, Bild 1 von 3 DBPOWER T20 Speaker Replacement: Schritt 3, Bild 2 von 3 DBPOWER T20 Speaker Replacement: Schritt 3, Bild 3 von 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Speaker Replacement: Schritt 5, Bild 1 von 2 DBPOWER T20 Speaker Replacement: Schritt 5, Bild 2 von 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Speaker Replacement: Schritt 6, Bild 1 von 3 DBPOWER T20 Speaker Replacement: Schritt 6, Bild 2 von 3 DBPOWER T20 Speaker Replacement: Schritt 6, Bild 3 von 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Speaker Replacement: Schritt 7, Bild 1 von 2 DBPOWER T20 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Speaker Replacement: Schritt 9, Bild 1 von 2 DBPOWER T20 Speaker Replacement: Schritt 9, Bild 2 von 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Speaker Replacement: Schritt 10, Bild 1 von 2 DBPOWER T20 Speaker Replacement: Schritt 10, Bild 2 von 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Speaker Replacement, Speaker: Schritt 11, Bild 1 von 2 DBPOWER T20 Speaker Replacement, Speaker: Schritt 11, Bild 2 von 2
    • Remove the two (3 mm) screws connecting the bracket down and pull out the reflector, using a J0 Philips Head Screwdriver.
  12. DBPOWER T20 Speaker Replacement: Schritt 12, Bild 1 von 3 DBPOWER T20 Speaker Replacement: Schritt 12, Bild 2 von 3 DBPOWER T20 Speaker Replacement: Schritt 12, Bild 3 von 3
    • Slide the mirror straight up to remove.
  13. DBPOWER T20 Speaker Replacement: Schritt 13, Bild 1 von 3 DBPOWER T20 Speaker Replacement: Schritt 13, Bild 2 von 3 DBPOWER T20 Speaker Replacement: Schritt 13, Bild 3 von 3
    • Slide out the power source and disconnect its cables from the power jack and the light.
  14. DBPOWER T20 Speaker Replacement: Schritt 14, Bild 1 von 3 DBPOWER T20 Speaker Replacement: Schritt 14, Bild 2 von 3 DBPOWER T20 Speaker Replacement: Schritt 14, Bild 3 von 3
    • Remove the screws holding down the first speaker with a J0 screwdriver.
    • Remove the screws holding down the second speaker down.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ryan Goldin
245 Reputation
1 Anleitung geschrieben
USF Tampa, Team S16-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 437
