Zum Hauptinhalt wechseln
DBPOWER T20 Fan Replacement
Was du brauchst
  1. DBPOWER T20 Fan Replacement, DBPOWER T20 Disassembly: Schritt 1, Bild 1 von 1
    • Flip the device and lay flat.
  2. DBPOWER T20 Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the four (9 mm) screws with a PH2 screwdriver.
    • Remove the two (7 mm) located with a PH2 screwdriver.
  3. DBPOWER T20 Fan Replacement: Schritt 3, Bild 1 von 3 DBPOWER T20 Fan Replacement: Schritt 3, Bild 2 von 3 DBPOWER T20 Fan Replacement: Schritt 3, Bild 3 von 3
    • Flip the device over and pry the top off with a plastic opening tool.
  4. DBPOWER T20 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
  5. DBPOWER T20 Fan Replacement: Schritt 5, Bild 1 von 2 DBPOWER T20 Fan Replacement: Schritt 5, Bild 2 von 2
    • Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
  6. DBPOWER T20 Fan Replacement: Schritt 6, Bild 1 von 3 DBPOWER T20 Fan Replacement: Schritt 6, Bild 2 von 3 DBPOWER T20 Fan Replacement: Schritt 6, Bild 3 von 3
    • Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
    • the black cable requires more force to remove than the other cables.
  7. DBPOWER T20 Fan Replacement: Schritt 7, Bild 1 von 2 DBPOWER T20 Fan Replacement: Schritt 7, Bild 2 von 2
    • Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
  8. DBPOWER T20 Fan Replacement: Schritt 8, Bild 1 von 1
    • Raise motherboard by lifting sideways and then up to avoid the ports.
  9. DBPOWER T20 Fan Replacement: Schritt 9, Bild 1 von 2 DBPOWER T20 Fan Replacement: Schritt 9, Bild 2 von 2
    • Remove wires attaching the piezoelectric speakers to the motherboard.
  10. DBPOWER T20 Fan Replacement: Schritt 10, Bild 1 von 2 DBPOWER T20 Fan Replacement: Schritt 10, Bild 2 von 2
    • Remove the five screws securing the black plastic cover with a J0 screwdriver.
    • Lift up and out to remove.
  11. DBPOWER T20 Fan Replacement, Fan: Schritt 11, Bild 1 von 2 DBPOWER T20 Fan Replacement, Fan: Schritt 11, Bild 2 von 2
    • Pull the fan up and out of the housing.
    • In this image the lamp and power input have been removed to increase visibility, you do not have to remove these to remove the fan.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S16-G2, Boczar Spring 2018 Mitglied von USF Tampa, Team S16-G2, Boczar Spring 2018
USFT-BOCZAR-S18S16G2
5 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Agustín Castiñeira Fernández - Antwort
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
Joan Abrines - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 1,114
