Zum Hauptinhalt wechseln
How to Fix a Stuck Trombone Tuning Slide
Was du brauchst
  1. How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: Schritt 1, Bild 1 von 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: Schritt 1, Bild 2 von 3 How to Fix a Stuck Trombone Tuning Slide, How to Fix a Stuck Trombone Tuning Slide: Schritt 1, Bild 3 von 3
    • Carefully remove the slides from the trombone.
    • If the slides are completely stuck, wiggle the slides from side to side while pulling it out of the trombone.
  2. How to Fix a Stuck Trombone Tuning Slide: Schritt 2, Bild 1 von 1
    • Clean each slide using a paper towel or cloth.
    • This will remove any friction the slides may have with the trombone.
  3. How to Fix a Stuck Trombone Tuning Slide: Schritt 3, Bild 1 von 1
    • Check to see if the tuning slides are parallel with their corresponding parts.
    • This can be done simply by aligning the slides against the trombone.
  4. How to Fix a Stuck Trombone Tuning Slide: Schritt 4, Bild 1 von 2 How to Fix a Stuck Trombone Tuning Slide: Schritt 4, Bild 2 von 2
    • If the slides are parallel, skip to step six. If not, attach each individual slide to the trombone and push/pull in the direction in which it would be parallel.
    • This will straighten the warped slides back into place.
    • Warped slides can be very difficult to move when attached to the trombone.
  5. How to Fix a Stuck Trombone Tuning Slide: Schritt 5, Bild 1 von 2 How to Fix a Stuck Trombone Tuning Slide: Schritt 5, Bild 2 von 2
    • Check to see if the slides are align once more.
    • Keep repeating step 4 if the slides are not lined up yet.
  6. How to Fix a Stuck Trombone Tuning Slide: Schritt 6, Bild 1 von 2 How to Fix a Stuck Trombone Tuning Slide: Schritt 6, Bild 2 von 2
    • Apply tuning slide grease to each slide.
    • Make sure each slide only gets a thin layer of grease. Too much grease could cause friction when attached to the trombone.
  7. How to Fix a Stuck Trombone Tuning Slide: Schritt 7, Bild 1 von 1
    • Attach the slides back to the trombone.
    • Position the slides to your liking and enjoy playing!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 2,025
