Zum Hauptinhalt wechseln
HP Pavilion dv7t-7000 RAM Replacement
Was du brauchst
  1. HP Pavilion dv7t-7000 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 RAM Replacement: Schritt 3, Bild 1 von 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 RAM Replacement, Back Panel: Schritt 4, Bild 1 von 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 RAM Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv7t-7000 RAM Replacement: Schritt 5, Bild 2 von 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 RAM Replacement, RAM: Schritt 6, Bild 1 von 2 HP Pavilion dv7t-7000 RAM Replacement, RAM: Schritt 6, Bild 2 von 2
    • Push the retraining springs away from the RAM at the same time to unlock the RAM.
  7. HP Pavilion dv7t-7000 RAM Replacement: Schritt 7, Bild 1 von 2 HP Pavilion dv7t-7000 RAM Replacement: Schritt 7, Bild 2 von 2
    • Pull the RAM out.
    • Follow the same procedure for the additional RAM.
Abschluss
Afnan
289 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 243
