Einleitung
This guide will show you how to replace the motherboard on a Nokia Lumia 930 smartphone.
Was du brauchst
Pull the SIM card holder out of the top of the phone using your fingernail.
Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
Use the flat end of a spudger to disconnect the camera connectors.
Pull the camera up and out to remove it from the phone.
Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
Remove the orange flex cable from the phone.
Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
Remove the antenna.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
