Zum Hauptinhalt wechseln
LG Risio Rear-Facing Camera Replacement
Was du brauchst
  1. LG Risio Rear-Facing Camera Replacement, Back Panel: Schritt 1, Bild 1 von 2 LG Risio Rear-Facing Camera Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Rear-Facing Camera Replacement, Battery: Schritt 2, Bild 1 von 1
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Rear-Facing Camera Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Rear-Facing Camera Replacement: Schritt 4, Bild 1 von 2 LG Risio Rear-Facing Camera Replacement: Schritt 4, Bild 2 von 2
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Rear-Facing Camera Replacement: Schritt 5, Bild 1 von 3 LG Risio Rear-Facing Camera Replacement: Schritt 5, Bild 2 von 3 LG Risio Rear-Facing Camera Replacement: Schritt 5, Bild 3 von 3
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Rear-Facing Camera Replacement: Schritt 6, Bild 1 von 1
    • Using your hand, pick up the midframe to separate it from the phone.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 129
