Zum Hauptinhalt wechseln
Nikon Coolpix S4000 Motherboard Replacement
Was du brauchst
  1. Nikon Coolpix S4000 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Nikon Coolpix S4000 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Push the orange tab back and the battery will pop out.
  3. Nikon Coolpix S4000 Motherboard Replacement, Casing: Schritt 3, Bild 1 von 3 Nikon Coolpix S4000 Motherboard Replacement, Casing: Schritt 3, Bild 2 von 3 Nikon Coolpix S4000 Motherboard Replacement, Casing: Schritt 3, Bild 3 von 3
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Nikon Coolpix S4000 Motherboard Replacement: Schritt 4, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Nikon Coolpix S4000 Motherboard Replacement: Schritt 5, Bild 1 von 3 Nikon Coolpix S4000 Motherboard Replacement: Schritt 5, Bild 2 von 3 Nikon Coolpix S4000 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Nikon Coolpix S4000 Motherboard Replacement, Lens Casing: Schritt 6, Bild 1 von 1
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Nikon Coolpix S4000 Motherboard Replacement: Schritt 7, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
  8. Nikon Coolpix S4000 Motherboard Replacement, Screen: Schritt 8, Bild 1 von 1
    • Remove the single 2mm Phillips #000 screw.
  9. Nikon Coolpix S4000 Motherboard Replacement: Schritt 9, Bild 1 von 3 Nikon Coolpix S4000 Motherboard Replacement: Schritt 9, Bild 2 von 3 Nikon Coolpix S4000 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
  10. Nikon Coolpix S4000 Motherboard Replacement: Schritt 10, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
  11. Nikon Coolpix S4000 Motherboard Replacement, Lens: Schritt 11, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement, Lens: Schritt 11, Bild 2 von 2
    • Remove the two 3mm Phillips #000 screws.
  12. Nikon Coolpix S4000 Motherboard Replacement: Schritt 12, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Turn the camera over and remove a single 4mm Phillips #000 screw.
    • There may be black tape covering the screw.
  13. Nikon Coolpix S4000 Motherboard Replacement: Schritt 13, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
  14. Nikon Coolpix S4000 Motherboard Replacement: Schritt 14, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
    • The tabs are brittle so use gently force.
  15. Nikon Coolpix S4000 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the orange ribbon cable out of the ZIF connector.
    • Separate the lens from the motherboard.
  16. Nikon Coolpix S4000 Motherboard Replacement, Motherboard: Schritt 16, Bild 1 von 1
    • Remove the two Phillips #000 screws securing the motherboard.
  17. Nikon Coolpix S4000 Motherboard Replacement: Schritt 17, Bild 1 von 2 Nikon Coolpix S4000 Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Pull the motherboard out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 228
