Zum Hauptinhalt wechseln
MSI GS70 Battery Replacement
Was du brauchst
  1. MSI GS70 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the laptop is turned off before starting.
    • Place laptop with the bottom plate facing up.
  2. MSI GS70 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove all screws using the JIS #1 screwdriver.
  3. MSI GS70 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the back plate.
    • Locate the battery.
  4. MSI GS70 Battery Replacement: Schritt 4, Bild 1 von 1
    • Locate the foil connector above the battery.
  5. MSI GS70 Battery Replacement: Schritt 5, Bild 1 von 1
    • Flip up both black clips with your spudger.
  6. MSI GS70 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the foil connector by pulling on the blue tabs.
  7. MSI GS70 Battery Replacement: Schritt 7, Bild 1 von 1
    • After the foil connector is removed you will see an 8 pin connector.
    • Disconnect the 8 Pin connector.
  8. MSI GS70 Battery Replacement: Schritt 8, Bild 1 von 1
    • Lift the battery and remove.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Perfect guide
storolle - Antwort
Anyone know what the foil connector is? Mine is broken, and needs to be replaced.
Jonathan Hawkes - Antwort
Which battery model should I buy?
slackware2007 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 46
Insgesamt: 8,924
