Zum Hauptinhalt wechseln
Archos Jukebox Recorder 20 Motherboard Replacement
Was du brauchst
  1. Archos Jukebox Recorder 20 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Motherboard Replacement, Button Panel: Schritt 3, Bild 1 von 1
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 5, Bild 1 von 2 Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the face.
  6. Archos Jukebox Recorder 20 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Remove four surrounding T5 screws as shown
  7. Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
  8. Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
  9. Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 9, Bild 1 von 2 Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
  10. Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 10, Bild 1 von 2 Archos Jukebox Recorder 20 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Desolder the remaining two points on the backside of the Jukebox.
    • The Motherboard should now be free from the frame and ready for repair or replacement.
Abschluss
Shaun Rifield
121 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G3, Freund Spring 2018 Mitglied von IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 400
