Zum Hauptinhalt wechseln
Sony Vaio PCG-61411L RAM Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Sony Vaio PCG-61411L RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Vaio PCG-61411L RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Vaio PCG-61411L RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L RAM Replacement: Schritt 2, Bild 1 von 3 Sony Vaio PCG-61411L RAM Replacement: Schritt 2, Bild 2 von 3 Sony Vaio PCG-61411L RAM Replacement: Schritt 2, Bild 3 von 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • The RAM cards reside in the rectangle shaped plate in the center of the back panel of the device.
  4. Sony Vaio PCG-61411L RAM Replacement: Schritt 4, Bild 1 von 2 Sony Vaio PCG-61411L RAM Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the single PH1 6mm screw at the top of the panel. The screw remains in the panel.
    • Remove the panel by lifting it towards yourself.
  5. Sony Vaio PCG-61411L RAM Replacement: Schritt 5, Bild 1 von 3 Sony Vaio PCG-61411L RAM Replacement: Schritt 5, Bild 2 von 3 Sony Vaio PCG-61411L RAM Replacement: Schritt 5, Bild 3 von 3
    • To remove the individual RAM card panels, snap back the metal latches on each side of the cards.
  6. Sony Vaio PCG-61411L RAM Replacement: Schritt 6, Bild 1 von 2 Sony Vaio PCG-61411L RAM Replacement: Schritt 6, Bild 2 von 2
    • After pinching the metal latches, the RAM card should pop out slightly upward.
    • Remove the cards by pulling them out to the left.
    • Repeat for the second panel of RAM cards.
Abschluss
Sean Lyon
381 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 10
Insgesamt: 1,156
