Zum Hauptinhalt wechseln
Sony Vaio PCG-61411L Hard Drive Replacement
Was du brauchst
  1. Sony Vaio PCG-61411L Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 2, Bild 1 von 3 Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 2, Bild 2 von 3 Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 4, Bild 1 von 2 Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 5, Bild 1 von 3 Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 5, Bild 2 von 3 Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 6, Bild 1 von 3 Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 6, Bild 2 von 3 Sony Vaio PCG-61411L Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sean Lyon
381 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G1, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 1,608
