Zum Hauptinhalt wechseln
Dell Vostro 1088 Hard Drive Replacement
Was du brauchst
  1. Dell Vostro 1088 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Vostro 1088 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the battery latches apart while at the same time slipping your forefingers into the groove at the center of the battery and pushing outward to disengage the battery from the computer.
    • Lift the battery from the computer.
  2. Dell Vostro 1088 Hard Drive Replacement, Access Panel: Schritt 2, Bild 1 von 2 Dell Vostro 1088 Hard Drive Replacement, Access Panel: Schritt 2, Bild 2 von 2
    • Remove the six screws that secure the access panel to the computer.
    • Remove the access panel from the computer.
  3. Dell Vostro 1088 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 2 Dell Vostro 1088 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Remove the four screws that secure the hard drive assembly to the computer.
    • Pull the plastic tab toward the opposite end of the hard drive assembly to disengage the hard drive interposer from the connector on the system board, then lift the hard drive assembly from the computer.
Abschluss
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 158
