Zum Hauptinhalt wechseln
Asus Vivobook Max X541SA-PD0703X Motherboard Replacement
Was du brauchst
  1. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 3, Bild 1 von 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 3, Bild 2 von 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 4, Bild 1 von 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 4, Bild 2 von 3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 6, Bild 1 von 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Disc Drive: Schritt 8, Bild 1 von 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 11, Bild 1 von 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 11, Bild 2 von 2
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 14, Bild 1 von 2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Pull the motherboard to the right and lift up.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Hetvi Mehta
781 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G4, Cagle Spring 2018 Mitglied von USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 3,096
