Zum Hauptinhalt wechseln
Spin Master Hatchimal Draggle Nose Replacement
Was du brauchst
  1. Spin Master Hatchimal Draggle Nose Replacement, Plastic Wing Replacement: Schritt 1, Bild 1 von 1
    • lay the Hatchimal on its side.
  2. Spin Master Hatchimal Draggle Nose Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool, push in on the purple clip.
  3. Spin Master Hatchimal Draggle Nose Replacement: Schritt 3, Bild 1 von 1
    • Pull the wing off of the hatchimal.
    • The wing should come off with little resistance.
  4. Spin Master Hatchimal Draggle Nose Replacement, Fur Replacement: Schritt 4, Bild 1 von 2 Spin Master Hatchimal Draggle Nose Replacement, Fur Replacement: Schritt 4, Bild 2 von 2
    • Cut the fur retaining zip-tie with a pair of scissors.
  5. Spin Master Hatchimal Draggle Nose Replacement: Schritt 5, Bild 1 von 2 Spin Master Hatchimal Draggle Nose Replacement: Schritt 5, Bild 2 von 2
    • Lift the fur up until it can't go further.
  6. Spin Master Hatchimal Draggle Nose Replacement: Schritt 6, Bild 1 von 3 Spin Master Hatchimal Draggle Nose Replacement: Schritt 6, Bild 2 von 3 Spin Master Hatchimal Draggle Nose Replacement: Schritt 6, Bild 3 von 3
    • Use the spudger tool to push up on the black clip to free it.
    • Pull the clip out.
  7. Spin Master Hatchimal Draggle Nose Replacement: Schritt 7, Bild 1 von 3 Spin Master Hatchimal Draggle Nose Replacement: Schritt 7, Bild 2 von 3 Spin Master Hatchimal Draggle Nose Replacement: Schritt 7, Bild 3 von 3
    • Lift fur up to reveal the next set of clips.
    • Insert a spudger to push up on the black clip to free it.
    • Pull out the clip.
  8. Spin Master Hatchimal Draggle Nose Replacement: Schritt 8, Bild 1 von 2 Spin Master Hatchimal Draggle Nose Replacement: Schritt 8, Bild 2 von 2
    • Lift the fur up and over the Hatchimals Head.
    • Remove the six 12mm Phillips #00 screws from then body.
  9. Spin Master Hatchimal Draggle Nose Replacement: Schritt 9, Bild 1 von 2 Spin Master Hatchimal Draggle Nose Replacement: Schritt 9, Bild 2 von 2
    • Pull the casing apart.
    • Remove the yellow speaker cable.
  10. Spin Master Hatchimal Draggle Nose Replacement: Schritt 10, Bild 1 von 3 Spin Master Hatchimal Draggle Nose Replacement: Schritt 10, Bild 2 von 3 Spin Master Hatchimal Draggle Nose Replacement: Schritt 10, Bild 3 von 3
    • Remove the three 7mm Phillips #00 screws from the head.
    • Remove the wheel base and the circuit board carefully not to damage the spring.
  11. Spin Master Hatchimal Draggle Nose Replacement: Schritt 11, Bild 1 von 2 Spin Master Hatchimal Draggle Nose Replacement: Schritt 11, Bild 2 von 2
    • Push the six black fur clips out using the spudger.
    • Remove the fur completely.
  12. Spin Master Hatchimal Draggle Nose Replacement, Nose Spring Replacement: Schritt 12, Bild 1 von 2 Spin Master Hatchimal Draggle Nose Replacement, Nose Spring Replacement: Schritt 12, Bild 2 von 2
    • Using the angled tweezers tool, disconnect the spring that is attached to the nose from the lever.
  13. Spin Master Hatchimal Draggle Nose Replacement: Schritt 13, Bild 1 von 1
    • Separate the body casing from the core and circuit board.
    • Don't damage the small wire connected from the top of the head to the circuit board.
  14. Spin Master Hatchimal Draggle Nose Replacement: Schritt 14, Bild 1 von 1
    • Remove a single 7mm Phillips #00 screw from the break.
    • Remove the spring.
Abschluss
Hector Lopez
251 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S1-G5, Nance Spring 2018 Mitglied von USF Tampa, Team S1-G5, Nance Spring 2018
USFT-NANCE-S18S1G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 496
