Einleitung
A replacement guide for the motherboard of the HP Pavilion dv7t-7000
Was du brauchst
Hold the release switch all of the way to the left and your other hand to pull the battery out.
Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
Pry upward to release the keyboard clips.
Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
Pull the ribbon cables out of the ZIF connectors.
Remove the keyboard.
Push the retraining springs away from the RAM at the same time to unlock the RAM.
Flip the keyboard back over.
Remove the single Phillips #00 screw holding in the CD drive.
Pull out the CD drive.
Remove the seventeen Phillips #00 screws securing the back panel to the laptop.
Use the flat end of a spudger to disconnect all wires connected to the motherboard.
Lift up the black tab on the ZIF connector with the flat end of a spudger.
Pull the ribbon cable out of the ZIF connector.
Remove the fan from the laptop.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
