Einleitung
Before removing the back panel, make sure the device is disconnected from any power source. Make sure that your battery has also been removed.
Was du brauchst
Use a Phillips #1 screwdriver to remove the two 2.5x8mm screws on the back panel.
Place the plastic spudger in the slot. Using the flat side of the spudger pry the back panel upward and off.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
