Zum Hauptinhalt wechseln
HP 15-R263DX Disassembly
Was du brauchst
  1. HP 15-R263DX Disassembly, Battery: Schritt 1, Bild 1 von 2 HP 15-R263DX Disassembly, Battery: Schritt 1, Bild 2 von 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
  2. HP 15-R263DX Disassembly, Optical Drive: Schritt 2, Bild 1 von 2 HP 15-R263DX Disassembly, Optical Drive: Schritt 2, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
  3. HP 15-R263DX Disassembly: Schritt 3, Bild 1 von 1
    • Gently slide the optical drive out of the side of the computer.
  4. HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: Schritt 4, Bild 1 von 2 HP 15-R263DX Disassembly, HP 15-R263DX Disassembly: Schritt 4, Bild 2 von 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
  5. HP 15-R263DX Disassembly: Schritt 5, Bild 1 von 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
  6. HP 15-R263DX Disassembly: Schritt 6, Bild 1 von 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
  7. HP 15-R263DX Disassembly: Schritt 7, Bild 1 von 2 HP 15-R263DX Disassembly: Schritt 7, Bild 2 von 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
  8. HP 15-R263DX Disassembly: Schritt 8, Bild 1 von 2 HP 15-R263DX Disassembly: Schritt 8, Bild 2 von 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
  9. HP 15-R263DX Disassembly: Schritt 9, Bild 1 von 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Washington State, Team S2-G3, Lobnitz Spring 2018 Mitglied von Washington State, Team S2-G3, Lobnitz Spring 2018
WSU-LOBNITZ-S18S2G3
8 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 24
Insgesamt: 6,242
