Zum Hauptinhalt wechseln
Dell Vostro 1710 Heatsink Replacement
Was du brauchst
  1. Dell Vostro 1710 Heatsink Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Vostro 1710 Heatsink Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Heatsink Replacement: Schritt 2, Bild 1 von 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Heatsink Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Heatsink Replacement, Back Panel: Schritt 4, Bild 1 von 2 Dell Vostro 1710 Heatsink Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Heatsink Replacement: Schritt 5, Bild 1 von 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Heatsink Replacement, Fan: Schritt 6, Bild 1 von 2 Dell Vostro 1710 Heatsink Replacement, Fan: Schritt 6, Bild 2 von 2
    • Unclip the power supply by pulling the cable directly up and out of the socket.
  7. Dell Vostro 1710 Heatsink Replacement: Schritt 7, Bild 1 von 2 Dell Vostro 1710 Heatsink Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 3mm screws located around the edge of the fan with a Philips #1 screw driver.
  8. Dell Vostro 1710 Heatsink Replacement: Schritt 8, Bild 1 von 2 Dell Vostro 1710 Heatsink Replacement: Schritt 8, Bild 2 von 2
    • Gently lift and pull to the left until the fan is free from the heatsink.
  9. Dell Vostro 1710 Heatsink Replacement, Heatsink: Schritt 9, Bild 1 von 2 Dell Vostro 1710 Heatsink Replacement, Heatsink: Schritt 9, Bild 2 von 2
    • Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
    • The screws do not come out, only loosen.
  10. Dell Vostro 1710 Heatsink Replacement: Schritt 10, Bild 1 von 2 Dell Vostro 1710 Heatsink Replacement: Schritt 10, Bild 2 von 2
    • Lift up on the heatsink to remove it from the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Tangxiao Sun
496 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 261
