Zum Hauptinhalt wechseln
Dell Inspiron 17-5749 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 17-5749 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 17-5749 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17-5749 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: Schritt 3, Bild 1 von 3 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: Schritt 3, Bild 2 von 3 Dell Inspiron 17-5749 Hard Drive Replacement, Back Cover: Schritt 3, Bild 3 von 3
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Dell Inspiron 17-5749 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Christopher Tran
1.161 Reputation
12 Anleitungen geschrieben
Washington State, Team S1-G2, Lobnitz Spring 2018 Mitglied von Washington State, Team S1-G2, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G2
6 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 642
