Zum Hauptinhalt wechseln
Acer Chromebook C720-2848 Keyboard Replacement
Was du brauchst
  1. Acer Chromebook C720-2848 Keyboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Chromebook C720-2848 Keyboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 Keyboard Replacement: Schritt 2, Bild 1 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 2, Bild 2 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 Keyboard Replacement, Battery: Schritt 3, Bild 1 von 3 Acer Chromebook C720-2848 Keyboard Replacement, Battery: Schritt 3, Bild 2 von 3 Acer Chromebook C720-2848 Keyboard Replacement, Battery: Schritt 3, Bild 3 von 3
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Acer Chromebook C720-2848 Keyboard Replacement: Schritt 4, Bild 1 von 2 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Acer Chromebook C720-2848 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Take out battery by lifting it up in the manner pictured.
  6. Acer Chromebook C720-2848 Keyboard Replacement, SSD: Schritt 6, Bild 1 von 2 Acer Chromebook C720-2848 Keyboard Replacement, SSD: Schritt 6, Bild 2 von 2
    • Unscrew screw holding SSD card in place.
    • Slide out the SSD card towards you to remove it.
    • The SSD card is the blue chip on the right connected to the motherboard.
    • Be sure to store this screw apart from the others as it is a different length.
  7. Acer Chromebook C720-2848 Keyboard Replacement, Motherboard: Schritt 7, Bild 1 von 3 Acer Chromebook C720-2848 Keyboard Replacement, Motherboard: Schritt 7, Bild 2 von 3 Acer Chromebook C720-2848 Keyboard Replacement, Motherboard: Schritt 7, Bild 3 von 3
    • Remove the three ribbon cables connected to the bottom of the motherboard.
    • Use the plastic spudger to lift the white hinges from on top of the ribbon cables.
    • Then gently pull the cables out.
  8. Acer Chromebook C720-2848 Keyboard Replacement: Schritt 8, Bild 1 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 8, Bild 2 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Remove 4 connectors from the right side of the motherboard.
    • All of these connectors release by simply pulling back.
    • To disconnect the connector shown in the third picture, you will need to peel back some tape first.
  9. Acer Chromebook C720-2848 Keyboard Replacement: Schritt 9, Bild 1 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 9, Bild 2 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 9, Bild 3 von 3
    • On the left side of the motherboard, remove one more connector and two cables.
    • To remove the cables, lift them up with a plastic spudger.
    • Take note of which cable connects where.
  10. Acer Chromebook C720-2848 Keyboard Replacement: Schritt 10, Bild 1 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 10, Bild 2 von 3 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 10, Bild 3 von 3
    • Remove the 2 fan screws and the 4 heat sink screws.
    • The screws don't necessarily need to be removed from the component, but rather just loosened enough to remove the component from the motherboard.
    • Now remove the fan/heat sink component.
    • Once again, make sure to keep these screws separate from all others.
  11. Acer Chromebook C720-2848 Keyboard Replacement: Schritt 11, Bild 1 von 2 Acer Chromebook C720-2848 Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Remove the 2 motherboard screws.
    • Now you can remove the motherboard.
    • Be careful not to damage any of the loose connectors and cables you disconnected in the previous steps.
  12. Acer Chromebook C720-2848 Keyboard Replacement, Keyboard: Schritt 12, Bild 1 von 3 Acer Chromebook C720-2848 Keyboard Replacement, Keyboard: Schritt 12, Bild 2 von 3 Acer Chromebook C720-2848 Keyboard Replacement, Keyboard: Schritt 12, Bild 3 von 3
    • Remove the 4 keyboard screws.
    • Lastly, remove the keyboard. To do this, slightly hinge open the laptop and pull back.
    • Make sure to be wary of the cables that connect to the display when removing the keyboard.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Baylor, Team S3-G1, Williams Spring 2018 Mitglied von Baylor, Team S3-G1, Williams Spring 2018
BU-WILLIAMS-S18S3G1
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
This should really be title keyboard ASSEMBLY replacement. The keyboard involves quite a bit more work on its own.
avarno - Antwort
! ATTENTION ! Comme l’a dit avarno il y a quelques mois, le tutoriel ne propose QUE DE REMPLACER LE BLOC CLAVIER + PAVÉ TACTILE. Sur Ifixit on peut aussi acheter le clavier seul (ce que j’ai fait). On se retrouve bloqué à l’étape 12. J’ai posté une solution en commentaire de l’étape 12 (peut être pas très conventionnelle, à vos risques et périls !)
adrien - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 623
