Zum Hauptinhalt wechseln
Dell Inspiron 1122 M102z Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 1122 M102z Display Assembly Replacement, Disconnecting the Mini-Card Antenna Cables: Schritt 1, Bild 1 von 1
    • Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 1122 M102z Display Assembly Replacement, Dislodging the Mini-Card Antenna Cables: Schritt 2, Bild 1 von 1
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Dell Inspiron 1122 M102z Display Assembly Replacement, Disconnecting the Display Cable: Schritt 3, Bild 1 von 1
    • Disconnect the display cable from the system board connector.
  4. Dell Inspiron 1122 M102z Display Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 1122 M102z Display Assembly Replacement, Removing the Display Assembly: Schritt 5, Bild 1 von 1
    • Lift and remove the display assembly off the computer base.
  6. Dell Inspiron 1122 M102z Display Assembly Replacement, Placing the Display Assembly: Schritt 6, Bild 1 von 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron 1122 M102z Display Assembly Replacement, Connecting the Display Cable: Schritt 7, Bild 1 von 1
    • Connect the display cable to the system board connector.
  8. Dell Inspiron 1122 M102z Display Assembly Replacement, Routing the Mini-Card Cables: Schritt 8, Bild 1 von 1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  9. Dell Inspiron 1122 M102z Display Assembly Replacement, Conencting the Mini-Card Antenna Cables: Schritt 9, Bild 1 von 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Abschluss
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 124
