Zum Hauptinhalt wechseln
Samsung SCV-VLUUST50 Flash Capacitor Replacement
Was du brauchst
  1. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: Schritt 1, Bild 1 von 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: Schritt 1, Bild 2 von 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Cover: Schritt 1, Bild 3 von 3
    • Unscrew all visible screws indicated by red circles with a #00 Phillips driver.
    • Slide memory card cover and unscrew hidden screw underneath with a #00 Phillips driver.
  2. Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 2, Bild 1 von 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 2, Bild 2 von 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 2, Bild 3 von 3
    • Remove the flat side panel by applying gentle pressure toward the bottom of the camera.
    • Remove the corner panel by applying pressure away from the shutter button.
    • The memory card cover will come off with the corner panel.
    • Remove the top panel by applying gentle pressure away from the shutter button.
  3. Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 3, Bild 1 von 1
    • Remove screws beneath the top panel indicated by red circles with a #00 Phillips driver.
  4. Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 4, Bild 1 von 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 4, Bild 2 von 2
    • Remove the front and back covers by pulling them straight apart.
  5. Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: Schritt 5, Bild 1 von 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement, Flash Capacitor: Schritt 5, Bild 2 von 2
    • Remove the screw securing the shutter button.
    • Lift the shutter button to remove it.
  6. Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 6, Bild 1 von 2 Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 6, Bild 2 von 2
    • Remove the 3 visible screws with a Phillips #000 Driver
    • Move the circuitry and wires out of the way to expose another screw, and remove it with the same driver.
  7. Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 7, Bild 1 von 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 7, Bild 2 von 3 Samsung SCV-VLUUST50 Flash Capacitor Replacement: Schritt 7, Bild 3 von 3
    • Pull the flash capacitor out of its compartment to expose the wires connected to it.
    • Cut the connecting wires with wire cutters.
    • Solder the wires to the new power source with a soldering iron and electrical solder.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 168
