Zum Hauptinhalt wechseln
Fujitsu Lifebook S6120 Keyboard Replacement
Was du brauchst
  1. Fujitsu Lifebook S6120 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Fujitsu Lifebook S6120 Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • To prevent injury, make sure the laptop is unplugged and turned off before removing the battery.
    • Push the two tabs in towards the laptop.
    • Lift the battery up and out from the frame of the laptop.
  2. Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: Schritt 2, Bild 1 von 2 Fujitsu Lifebook S6120 Keyboard Replacement, Hinge Cover: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to lift the back of the hinge cover on the left and right sides of the computer.
  3. Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the hinge cover.
    • The hinge cover is connected to the motherboard by a ribbon cable. To prevent damage, lift hinge cover slowly.
  4. Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 4, Bild 1 von 3 Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 4, Bild 2 von 3 Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Use the tweezers to disconnect the ribbon cable from the motherboard.
  5. Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 5, Bild 1 von 3 Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 5, Bild 2 von 3 Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • With the tweezers detach hinge cover cables from the motherboard.
    • Remove hinge cover.
  6. Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: Schritt 6, Bild 2 von 3 Fujitsu Lifebook S6120 Keyboard Replacement, Keyboard: Schritt 6, Bild 3 von 3
    • Lift keyboard enough to show the ribbon cable.
    • The keyboard has a ribbon cable attached to the motherboard. Lift keyboard carefully to prevent damage.
  7. Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 7, Bild 1 von 3 Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 7, Bild 2 von 3 Fujitsu Lifebook S6120 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to release the ribbon cable from the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jessi Gallant
899 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S5-G5, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S5-G5, Peak Spring 2018
UMASSD-PEAK-S18S5G5
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 1,069
