Zum Hauptinhalt wechseln
Cuisinart CHW-12 Power Cord Replacement
Was du brauchst
  1. Cuisinart CHW-12 Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 2 Cuisinart CHW-12 Power Cord Replacement, Power Cord: Schritt 1, Bild 2 von 2
    • Unplug the coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Cuisinart CHW-12 Power Cord Replacement: Schritt 2, Bild 1 von 2 Cuisinart CHW-12 Power Cord Replacement: Schritt 2, Bild 2 von 2
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Cuisinart CHW-12 Power Cord Replacement: Schritt 3, Bild 1 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 3, Bild 2 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 3, Bild 3 von 3
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Pull the gray ribbon cable strait out of the black containment box.
  4. Cuisinart CHW-12 Power Cord Replacement: Schritt 4, Bild 1 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 4, Bild 2 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 4, Bild 3 von 3
    • Locate the Phillips head screws holding the highlighted plastic shield in place.
    • Remove the two 14mm screws with a Phillips head screwdriver.
    • Carefully slide the shield out of place along the power cord and set it aside.
  5. Cuisinart CHW-12 Power Cord Replacement: Schritt 5, Bild 1 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 5, Bild 2 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 14mm Phillips head screws securing the plastic containment box.
    • Pull the plastic containment box straight out of the coffee maker.
  6. Cuisinart CHW-12 Power Cord Replacement: Schritt 6, Bild 1 von 2 Cuisinart CHW-12 Power Cord Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
    • Pull the top from the plastic housing.
  7. Cuisinart CHW-12 Power Cord Replacement: Schritt 7, Bild 1 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 7, Bild 2 von 3 Cuisinart CHW-12 Power Cord Replacement: Schritt 7, Bild 3 von 3
    • Pull the circuit board out of the containment box.
    • Locate the power cable connection point on the circuit board.
    • Desolder the power cable wires connected to the board.
    • Solder iron can cause burns if used improperly.
    • Replace the power cable with the corresponding wires of the new power cable.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Houston State, Team S17-G2, Blackburne Spring 2018 Mitglied von Sam Houston State, Team S17-G2, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 34
Insgesamt: 1,746
