Zum Hauptinhalt wechseln
HP Pavilion G60-247CL Screen Replacement
Was du brauchst
  1. HP Pavilion G60-247CL Screen Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Screen Replacement, Screen: Schritt 2, Bild 1 von 1
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  3. HP Pavilion G60-247CL Screen Replacement: Schritt 3, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the seven Phillips #0 screws from the battery compartment.
  4. HP Pavilion G60-247CL Screen Replacement: Schritt 4, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 4, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 4, Bild 3 von 3
    • Turn the computer around to the front side.
    • Using an opening tool (Spudger), prop open the keyboard casing.
  5. HP Pavilion G60-247CL Screen Replacement: Schritt 5, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 5, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 5, Bild 3 von 3
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  6. HP Pavilion G60-247CL Screen Replacement: Schritt 6, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 6, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 6, Bild 3 von 3
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  7. HP Pavilion G60-247CL Screen Replacement: Schritt 7, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 7, Bild 2 von 2
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  8. HP Pavilion G60-247CL Screen Replacement: Schritt 8, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 8, Bild 2 von 2
    • Remove the black wire from the top right corner by gently pulling outward.
  9. HP Pavilion G60-247CL Screen Replacement: Schritt 9, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 9, Bild 2 von 2
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  10. HP Pavilion G60-247CL Screen Replacement: Schritt 10, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 10, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 10, Bild 3 von 3
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  11. HP Pavilion G60-247CL Screen Replacement: Schritt 11, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 11, Bild 2 von 2
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  12. HP Pavilion G60-247CL Screen Replacement: Schritt 12, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 12, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 12, Bild 3 von 3
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  13. HP Pavilion G60-247CL Screen Replacement: Schritt 13, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 13, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 13, Bild 3 von 3
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  14. HP Pavilion G60-247CL Screen Replacement: Schritt 14, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 14, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 14, Bild 3 von 3
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  15. HP Pavilion G60-247CL Screen Replacement: Schritt 15, Bild 1 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 15, Bild 2 von 3 HP Pavilion G60-247CL Screen Replacement: Schritt 15, Bild 3 von 3
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  16. HP Pavilion G60-247CL Screen Replacement: Schritt 16, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 16, Bild 2 von 2
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  17. HP Pavilion G60-247CL Screen Replacement: Schritt 17, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 17, Bild 2 von 2
    • Prop the screen up slightly .
    • Using the tweezers unclip the white wire.
  18. HP Pavilion G60-247CL Screen Replacement: Schritt 18, Bild 1 von 2 HP Pavilion G60-247CL Screen Replacement: Schritt 18, Bild 2 von 2
    • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  19. HP Pavilion G60-247CL Screen Replacement: Schritt 19, Bild 1 von 1
    • Remove the screen from the outer casing carefully.
Abschluss
Haley Matthews
517 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S4-G5, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G5, Covino Spring 2018
UMASSD-COVINO-S18S4G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 268
